Spark controller firmware update
16627 22 2017-9-11
Superman8
Flight distance : 13 ft
Please help to resolve spark controller firmware update (in compatiblity update or lacking update log) stop at 5%.
2017-9-11
DJI Elektra
DJI Team
China
Please ensure that you have a solid wifi. Or you can try to change another mobile device and reinstall your app.Thanks.
2017-9-11
Raj63
Singapore
Have the same issue. Did you resolve this and what did you do to get this done. Really miss flying my drone
regards
2017-9-11
djiuser_p9iKG3X
Mexico
I have the same problem   spark controler update  log  stopt at 5%,,,  using a  Samsung Galaxy 7,, please help to solve this isue
2017-9-11
DronerX
Flight distance : 488192 ft
djiuser_p9iKG3X Posted at 2017-9-11 18:50
Try updating using the DJI Assistant 2 software.
MY APOLOGIES - my advice was for the AC firmware, NOT the RC software.
2017-9-11
djiuser_p9iKG3X
Mexico
,,,,,I try but the RC can be update only  by  the DJI GO4,,,,
2017-9-11
Neil_Vals
Flight distance : 158812 ft
this was resolved from another thread
https://forum.dji.com/thread-112074-1-1.html
I got spark fly more combo. I uninstall DJI Go 4 app 4.1.8 then restart phone. install 4.1.5 dji go4 app from apk given from above thread then install the remote firmware successfully.  Then reinstall the latest 4.1.8 DJI Go 4 app before I fly. works for me . Good Luck Safe Flying.
2017-9-11
DJI Diana
Flight distance : 2408 ft
Raj63 Posted at 2017-9-11 18:22
regards
Please try to upgrade the RC via iOS app, or download the Android DJI GO 4  V4.1.5 to upgrade the RC, you'll be able to upgrade it successfully.
2017-9-11
DJI Diana
Could you please also try the methods which I provided in the post 8#?
2017-9-11
Raj63
Singapore
DJI Diana Posted at 2017-9-11 20:12
Thanks a lot Dji Diana
For everyone else,
I am not a savvy "drone updater", so I will explain step by step what I did an hope it will helps anyone else. If I missed out anything do add on after
Note: This is for a android phone
Step 1.  Uninstall the current  DJI Go 4 (does not work for the latest version)
Step 2.  Download the older Dji Go 4 v 4.1.5 from this site:
https://www.apkmirror.com/apk/dj ... droid-apk-download/
Step 3.  Install the older version by opening it from your file manager
Step 4.  Open your older Dji Go 4 app
Step 5.  Link wifi to RC. (not sure if this is needed but did it anyway)
Step 6.  Go to the Dji Go 4 app and setup with the steps requested
Step 7.  Click the update firmware 'button' at the top and at a prompt to set wifi to a normal wifi, change the wifi to an external wifi
Step 8.  Download the firmware
Step 9.  Set wifi back to the RC
Step 10.  GOOD TO GO !
Hope this helps.
regards
2017-9-12
Sparky_17
Flight distance : 62349 ft
Raj63 Posted at 2017-9-12 05:02
For everyone else,
Thanks for sharing this information.  Hope it helps a lot of people using Android devices.
2017-9-12
Wachtberger
Flight distance : 261509 ft
For everyone else,
Well done and perfect description! Once you have successfully updated everything I would however recommend you to return to the latest App version. It has bugfixes and works well except for the updates. Since DJI is aware now about that problem, I have no doubt that we will get a fixed and well tested App version before the next firmware updates will have to be installed.
2017-9-12
Anuvis
Flight distance : 1976736 ft
Greece
Come on DJI Mod make a sticky thread  with the solution to this problem....12256152 threads about the same problem....This is awful ....
2017-9-12
djiuser_vFjFgfu
Singapore
Follow the below steps from 1 of the member, it solved my problem which was same as your...
Read it first from 1-9. You should follow exact steps step-by-step to succeed.
1. Power up your Sparky.
2. Press Power button 9 seconds (3 Beeps)
3. Restart your Spark (power off and on again)
4. Press Power button 6 seconds (2 beeps)
5. Restart your Spark.
6. Press Power button 3 seconds (1 beep)
7. Now Power up your remote (just now).
8. Wait till Red light will stop blinking and just remain red.
9. Now press 3 keys on your remote to start the connection.
Do not forget about distance (<20cm) and you'll get it paired in less than 30 seconds from now.
Good Luck!
2017-9-12
Raj63
Singapore
Wachtberger Posted at 2017-9-12 05:20
Thanks a lot Wachtberger. Got some of the steps from your log. Had problems updating still and thought other newbees would too. So I share the steps I used that worked.
2017-9-12
Wachtberger
Thanks, but it did not come from me, I only had quoted the author of the good solution. But happy to read that it works for you too now!
2017-9-12
djiuser_psS0oho
i have the same problem with android devices ( s7 edge, nexus 7, htc one ) then i tryd the ipod touch (ios) and there was no update massage any more ???
2017-9-12
djiuser_ZfnEctU
Brazil
Good Morning ! apacece that phrase in my drone dji spark what would it be? Latest Firmware Abnormal
2017-9-13
DJI Elektra
DJI Team
djiuser_psS0oho Posted at 2017-9-12 22:56
Please check the current version of your RC , if it is not the latest version, please try to use the old version of DJI GO 4 and update it again. Here is the link:
https://www.dropbox.com/s/ymau5f ... 1.5.3_guan.apk?dl=0
2017-9-14
DJI Elektra
DJI Team
China
djiuser_ZfnEctU Posted at 2017-9-13 06:55
Please provide me a screenshot about this warning.
Any other error message?
Thanks for support.
2017-9-14
DJI Diana
For everyone else,
Glad to hear that you've got it resolved, hope you can enjoy the drone! Thanks for sharing this with us, it is helpful.
2017-9-14
Spark_annon
Flight distance : 8783 ft
Its been fixed,just updatr your dji go 4 app and it works now...i was going nuts with the rc problem updating
2017-10-14
fans3f4b5480
Mexico
hi people!!
can you help me please?
i was able to download both firmware for RC and for spark.
however its imposible fly, remains the advertisement: can’t take off and request the latest version!!
what can i do?? please
2017-10-28
