DJI Elektra
Bytestorm Posted at 2017-9-12 01:15
Austria also has the 79 Joules-rule. It means this is the maximum of force allowed if the drone crashes to the ground. It can (roughly) be calculated with weight and height of the aircraft. For the spark it means, you are not allowed to fly higher then about 26m, not including the forward-thrust.
But much more important: local regulations are changing a lot in most countries in the last years. I would never trust an online-site or forum regarding laws. I did read one thing while reading about this topic in various blogs and forum, that I felt is the most important truth: ask your local embassy, in this case the Croatian embassy in Denmark. In this case you can be sure you got the latest information and maybe also can print that out and take it with you on your journey.
Bytestorm, thanks for your help and it is wise to learn information from local embassy. |
