S-e-ven
Flight distance : 5922034 ft
Thailand
djiuser_u7hRt3UikPfT Posted at 10-29 18:47
Great Thanks that makes a ton of sense.
The $150 (AUD) lenovo E8" is great reasonable specss re CPU memory etc Micro usb port only. it connects via OTG cable or wifi and runs litchi and DJI Go 4 well . But just like the phone virtually impossible to see in sunny conditions even with a hat, a sunshroud and anti glare You have to get under shade to have a fighting chance of seeing the screen/app
1GB Ram, only?
That seems to be a bottleneck!
And still on Android 7?
I have doubts, that it will be able to handle the stream and such, but good luck anyway.
Just : I'd suggest to use an older Go4 Version, go to apk mirror and download the 4.2.21 from there.
I run that Go 4 on my flight devices, it gets you (imho) all you need for the Spark.
And RTH has NOTHING to do, with a mobil phone connection.
Just with the GPS the bird finds and set the HP too!
So make sure, you just start the bird after "home point got updated, please check it on the map", and you should be good to go and come back
