brian_b
Hardware agnostic here - I despise fanboy wars. Iʻve worked on both PC and Mac, and at this point in my career, Iʻve worked on custom purpose built PCs for editing, and prohibitively expensive Macs and both can do the job comparably IMHO. Where I work, the editors do use Final Cut Pro X, though we do have Adobe subs and those will take over eventually. I use PC/Premiere at home and it does perfectly fine. One note, though, if you do use Premiere, youʻll need to set your sequence to 30 fps and interpret your imported footage 30fps non drop frame. You donʻt have to run it through anything and it will be smooth. |
