DonBishop
DJI Mindy Posted at 2017-9-20 22:42
DonBishop, sorry to have kept you waiting for the reply. Since there are no other users reporting the same problem after firmware update, we still need clarify more details with you.
1. Did you start recording videos by APP or pressing Record Button in handle?
2. SD card saves 4G as a clip, it will stop while the recording file is larger than 4G and continue with creating a new file automatically. Do you mean the clips between them lost?
Not lost, as in missing. Corrupted. Unable to move from the SD card to the computer. I have had the same issue when using the stock SD card, and use the larger card when I know I am going to be shooting a lot of video. The issue has not recurred, because I am no longer using the OSMO. I simply do not trust it.
And, what difference does it make which button I push? If one button is no good, eliminate it! |
