Jenee 2
Flight distance : 7852129 ft
DJI Thor Posted at 2017-9-20 00:35
Let me make it clear of your situation first, so you are using a Mavic Pro and Phantom 4 Pro on the same app on your iPad mini 4, you first connect the app with your P4P, change the white balance setting, after using P4P, you connect the app with your MP, then the white balance now is the MP's, if you change it to something like Cloudy, it will always stay on Cloudy even if you connect P4P afterward and then change again back to MP, but on the contrary, P4P will not stay, am I right? Or something else? And what if you change the white balance of P4P, shut it down and connect to the app again, will it be saved?
If I set the White Balance to say sunny on the P4Pro, fly, then shut it down and then fly again, the White Balance will stay on sunny or whatever I set it to.
If I fly the P4Pro and set the White Balance to sunny or something else other than auto, then I shut it down and fly the Mavic with the White Balance on sunny. I shut down the Mavic and fly the P4Pro again, the White Balance will now be auto. If I fly the Mavic again, the White Balance will still be on the setting it had the last time I flew it.
The setting for White Balance for the Mavic is retained.
The setting for White Balance for the P4Pro is changed to auto if I had previously flown the Mavic. |
