PedramN
Iran
fansa7dc5944 Posted at 2017-9-13 02:51
At altitude below 8 m. if there is sufficient GPS then GPS is used otherwise VPS. At altitude over 8 m. where no GPS available it goes ATTI.
Hi to all, in fact it would be a great idea that helps many pilots having limitted flying experience in ATTI mode, if the little sparky uses VPS for stabilizing AC in ATTI mode. In such scenario, if due to any reason, spark encounters compass error and dropping GPS, she can descent using barometer reading to the height that VPS Recognize First detectable pattern 8meters below AC (may be tall trees tops below sparky even) And then using pattern for stabilized hovering till compass error resolves or using VPS for stabilized fly with stick commands such as named P-VPS when flying indoors without gps. VPS readings are processed differently and are relative according to below surface pattern and are interpretable Without Compass. Using VPS readings, crash landing or accident with below surface is not probable much, because descent of AC will stop 8 meters above first obstacle. Please DJI consider this as a possible solution for those atti mode situations and make Spark even more Greate. |
