Dobmatt
Flight distance : 1831050 ft
It's the compass in Android device that need calibration or - eventually - a fix. Go app uses it's readings to compare with AC compass and position the arrow accordingly on the map. Check AC compass (actually 2 compasses) performance on sensors state page in Go app. If it's good, than your craft should move straight forward aligned with arrow configuration, regardless it's position superimposed over map. But - if I understand correctly - your arrow is consistently off big time. That's not good, you need to know where your craft is heading when beyond VLOS. Arm your system and do that horizontal "figure 8" walk with RC before take off ... Maybe that's all what's needed to teach the build-in Android device where the North Pole actually is located ... Mine is smarter than your's, BTW ... |
