Formatting New Memory Card
TGoedde
I bought an 128GB ScanDisk memory card for greater capacity. How do I format it? I have popped the card in and the drone flashes amber lights. I do not see anything on the ipad app showing a warning or what to do. Is this card too acceptable?
2017-9-13
TGoedde
OK. Seems to format on its own, but no pictures stores in the DCIM folder. More testing needed or a fancy tip from the good folks in FORUM.
2017-9-13
Aardvark
Flight distance : 384432 ft
TGoedde Posted at 2017-9-13 10:51
At the bottom of the 'Aircraft Status' menu (tap at the top of DJI Go 4 screen) there is the option to format SD card, similarly in the 'camera settings' menu.
2017-9-13
ALABAMA
Flight distance : 10442687 ft
Am I wrong, or is that size too big?
2017-9-13
RedHotPoker
Flight distance : 165105 ft
I use a 64gb micro sd card and find it perfect for my four flight batteries, recording at 4K. Awesome.
I only format my cards in the drone, never in my hp desktop computer.
RedHotPoker
2017-9-13
Landbo
Flight distance : 502792 ft
Denmark
DJI's cameras will only support SD cards up to 64 GB.
Regards Leif.
2017-9-13
Genghis9
Flight distance : 961 ft
ALABAMA Posted at 2017-9-13 11:38
Not for a P4P, they didn't say, but indicates a P4A, I'd think the Advanced would have same parameters as a Pro...
Edit: 128 is the max, ref pg 45 v1.2
Just reviewed P4A manual v1.0 pg 45 states up to 128 is supported
2017-9-13
ALABAMA
Genghis9 Posted at 2017-9-13 13:57
Didn't know that.  Thanks for the info!
2017-9-13
DJI-Mark
Please make sure that the SD card you are using is one that is compatible with this aircraft. As stated before, you will need to format through the App.
2017-9-14
DJI Thor
Flight distance : 13602 ft
Besides, just to verify, the files can be stored on the SD card, right? If so, could you please also provide us a screenshot of the image transmission interface with the SD card spec?
For the formatting, you can do it both on DJI GO 4 and the computer. DJI GO 4: connect the drone, camera settings, the third page, the choice on the last but one.
2017-9-17
