Phantom 4 Pro camera is really 4K?
12Next >
10542 56 2017-9-13
fansde3bbad0
Flight distance : 388068 ft
Colombia
I have a Phantom 4 pro a few months ago already, but almost since the beginning I was not too much impressed with the quality obtained, specially with the 4K videos, now I think that could be due to a technical feature that I wish to be very very wrong about it.
In these 3 100% crops are something in common: signals of interpolation or deinterlacing, as you can see in the stairs like artifacts on each diagonal and line captured by the P4P camera, this kind of artifacts can be found on deinterlaced footage converted to progressive or in FullHD upscaled to 4k:
so... P4P camera is really 4K? I have another 4K cameras and none of their footage presents this kind of artifacts.
These are the details of the video where the crops were taken:
https://www.dropbox.com/s/ovstiwrj3cchjhr/video_details.jpg?dl=0
2017-9-13
PaulSouthport
Flight distance : 1448799 ft
Is the video from the SD card or the mobile device?
EDIT: ignore that, I missed the dimensions on the clip
2017-9-13
method007
Flight distance : 110449 ft
Yup, it's 4K.  It's just not the best.
2017-9-14
Capt Whitefoot
I'm not sure what the situation is with your P4P, but with mine, it shoots exceptional 4k.  It makes 1080p look way lower quality.
2017-9-14
Nigel_
Flight distance : 388642 ft
It doesn't have a 4K image sensor, the sensor is bigger than 4K but not a nice 2x so a perfect scaling is not possible.
Most of your image looks like decent 4K though, maybe a little out of focus on the closer bits of the bridge.
I wonder if the issue you are seeing is a result of stabilisation trying to remove vibrations?
Are your propellers well balanced or do they vibrate a lot?
2017-9-14
SM-17
Flight distance : 179288 ft
Malta
What sharpness settings are you using?
2017-9-14
gt3rs
Flight distance : 280056 ft
Switzerland
up to 4k 30fps the quality is quite good and better than most small sensor cameras e.g. gopro, mavic, phones but above 30fps p4p is doing line skipping so it introduces aliaising and you loose vertical resolution.... try filming at home without flying a test chart or news paper at 4k 30 and 60 and compare.
2017-9-14
fansde3bbad0
Colombia
Nigel_ Posted at 2017-9-14 07:59
Well I was sure the conditions were as stable as P4P can offer, and in this matter it does a very good job, it seems like line skipping or a kind of de-interlacing.
2017-9-14
fansde3bbad0
Colombia
gt3rs Posted at 2017-9-14 12:10
Thanks a lot for your comment, and well, I think you are right, I've compared with another 4K@30fps footage and I couldn't found the same issue, so certainly is line skipping, perhaps to achieve the higher frame rate, thus, the conclusion could be that P4P is not a real 4K/UHD at 60fps, that is a quite bad news because must of the cases people shoot at 60fps for slow motion where the artifacts became even more visible. This is a huge negative point for P4P.
2017-9-14
Geebax
fansde3bbad0 Posted at 2017-9-14 21:08
It is not line skipping. To do that the sensor must have a vertical resolution at least equal to twice the target vertical resolution, otheriwse you would see horendous aberrations in the picture. The answer is shown in the properties window of the OP's grab. Look at the properties.
2017-9-14
Montfrooij
Flight distance : 2560453 ft
You might be on the right track with the stabilization and the scaling down.
2017-9-15
Montfrooij
Geebax Posted at 2017-9-14 21:52
I'm missing it I guess.
2017-9-15
DJI Diana
Flight distance : 2408 ft
If you could upload an original 4k video from the SD card to the Dropbox, then provide me a link to download it, I'll forward it to our engineer for analysis.
2017-9-15
Sebb
Flight distance : 498199 ft
The P4p sensor is the same as in the Sony RX100m4, so we know a fair bit about it. So YES, it is true 4K. Quite good 4K, actually!
However, the main point to keep in mind is: you cannot compare a video still to a JPEG photo, in case that is what you did...  it will always look considerably less sharp  (that goes for practically all cameras)
Why?
image processors use shortcuts to handle the massive amount of image data coming off sensors.
1. Pixel binning / line skipping = not all pixels are used to compile the image. P4p has 20MP sensor and will only use a portion of the total 20mio pixels to create an 8MP = 4K image frame. this results in significant loss of sharpness, moire and aliasing (compared to a native 8MP photo).
2. Chroma Subsampling = color information from 4 pixels are combined and averaged into 1. that results in noticeable loss in clarity.
bottomline.. on basically every camera, video frames will look nowhere near as good as photos off the same sensor, even at same resolution.
what other 4K cameras do you have / are you comparing?
disclaimer: half-baked amateur talking here . ..
2017-9-15
fansde3bbad0
Colombia
Sebb Posted at 2017-9-15 01:56
One of the reasons I decided for P4P was just Sony is using the same sensor.
The crops were extracted from a 4k@60fps video, aren't stills, they were encoded carefully to avoid another artifacts different to the mentioned one in this post, the issue is clearly regular, is not due to compression, or something similar, we can see an ordered pattern just one scanline after another, like the ones we can see in a de-interlaced or line-skipped video frame.
I can confirm the issue is only present in 4k@60fps videos not in 4k@30fps, so must be something associated with the framerate.
2017-9-16
fansde3bbad0
Colombia
DJI Diana Posted at 2017-9-15 01:26
Hi,
Well, the video I use for the crops is quite long and big, so I uploaded a couple of short ones where the issue can be noted too:
Video Link:
http://3dlogical.com/_temp/dji/DJI_0061.MOV
You can note the issue on the white lines over the field
Video Link:
http://3dlogical.com/_temp/dji/DJI_0018.MOV
You can note the issue looking at the mountains silhouette.
These videos are unprocessed, unedited, untouched
2017-9-16
lannes
Flight distance : 4465 ft
Could it be something to do with SD Card write speed ?
2017-9-16
Geebax
lannes Posted at 2017-9-16 22:40
The SD card has nothing whatsoever to do with the image quality. It is a digital recording, not analog.
2017-9-16
Geebax
fansde3bbad0 Posted at 2017-9-16 14:11
Hi,
'These videos are unprocessed, unedited, untouched'
The videos might be, but the crops certainly are not. You cannot expect to crop an image like that without creating distortions. The short clip you linked to looks perfect, why are you pixel-peeping?
2017-9-16
Sebb
fansde3bbad0 Posted at 2017-9-16 13:34
yes of course high framerates always results in significantly decreased image clarity.
4K60 on P4pro is usable but nowhere near 4K30.
2017-9-18
DJI Diana
Hi,
Thanks, I've forwarded them to our engineers, will keep you updated.
2017-9-18
charlesetischer
The sensor of P4P has about 5470 pixels horizontally and the 4K video is down-scaled from the 5.4K RAW, thus making it sharper and less noisy than directly cropping a 4K window on the sensor.
Unlike 4K 30fps which has square pixels, the 4K 60fps footage is generated from 5.4K RAW with rectangular logical pixels. This technique allows to make full use of the same area of the sensor as that in 4K 30fps mode and keep the full FOV, without sacrificing dynamic range (compared to 4K windowed readout). It is beyond the performance limit of the sensor to readout 5.4K square pixels at a rate of 60fps.
2017-9-18
fansde3bbad0
Colombia
Geebax Posted at 2017-9-16 23:17
You must have in mind what 100% crop means, they are unscaled 320x320, undistorted, unprocessed images extracted directly from a video frame, and uncompressed because were stored in PNG, so there are no chances to incorporate distortion of any kind from anywhere, any artifact that you could see in those crops actually exists in the video. To obtain unaltered crops of a video I use AfterEffects or Photoshop TimeLine, the video frame is saved directly from a selected frame on the timeline in PNG format, cropped and stored in PNG again, there is no chance that in such as process some distortion, compression artifact or visual contamination be incorporated. But with the video links I provided you can do the crops by yourself and see what I'm seen by your own.
2017-9-18
fansde3bbad0
Colombia
fansde3bbad0 Posted at 2017-9-18 08:27
This is a screen recording showing the process I did to extract 100% crops and compare the differences between 4K@60fps and 4K@30fps of the same subject with the same lighting and ambient conditions, I drop here the links of the videos used for the analysis and the 100% crops extracted from them just made at my house:
Process:
http://3dlogical.com/_temp/dji/ProcessCapture.mp4
4K video at 60fps:
http://3dlogical.com/_temp/dji/DJI_0344.MOV
4K video at 30fps:
http://3dlogical.com/_temp/dji/DJI_0345.MOV
100% Crop 1 at 60fps:
http://3dlogical.com/_temp/dji/Crop@60fps.png
100% Crop 2 at 30fps:
http://3dlogical.com/_temp/dji/Crop@30fps.png
So I hope this is much more clear and generate less confusion  about the cropping and extracting process..
2017-9-18
R&L Aerial
Flight distance : 298100 ft
You may have a defective unit, my p4 advanced shots great 4k
2017-9-18
DJI Diana
Hi,
Hi, our engineers replied you in the post 22#, please check it.
2017-9-18
Sebb
charlesetischer Posted at 2017-9-18 05:59
i m not sure i understand fully what you re describing, however we do know that
- sensor can readout full resolution (20.2MP) at maximum 25fps = using all pixels
- sensor can readout cinema 4K resolution (9MP) at maximum 60fps = using partial scan
AFAIK actual framerate limitations of the camera are always introduced by the picture processer - the component that handles RAW uncompressed data frames and encodes them into compressed frames at a certain bitrate, encapsulated into a container. The RX100 m4/m5 for example cannot produce 4K60 frames, despite the sensor having such a readout mode. The Bionx processor can only effectively handle 30fps and already overheats after 5min as it is.
regarding different image quality, I highly doubt that 24/30fps video is using full readout mode (which doesnt even do 30fps), and only 60fps uses partial scan mode.
Today only few consumer cameras actually do 4K with full readout, since it requires siginificant processing. and since it is a premium feature, it is immediately included into marketing. See for example A6500 "4K movie recording with full pixel readout/no pixel binning". We dont see this with P4pro. RX100 also lack it which is expected at this price point.
having said that, all 4K modes with P4pro come from 9MP / 4.5K readout which is partial scan which has to be enlarged again, hence softer image. My assumption then is that 24/30fps can be compiled at full quality into quite clean 4K, while 60fps sacrifices yet additional pixels or lines, resulting in noticably softer footage.
not sure where you got your information, but please share any additional insights.
sorry for long post
2017-9-25
DJI_camera
DJI R&D Squad
Sebb Posted at 2017-9-25 06:56
That is not correct. No modes of P4P come from 9MP/4.5K readout. Everything at or below 60fps is from 5.4k horizontal readout.
The P4P's 30fps video formats all come down from 5.4k (about 16.8M pixels), using the full width of the sensor. The 60fps modes also use 5.4K horizontally, but each logical pixel is not square, so the minimum resolvable detail in the vertical direction is not as good as in the horizontal direction. However, the readout window still covers the same area as the 30fps modes (using the full width of the sensor), so the FOV does not change and we do not waste the noise performance of the Type 1'' sensor.
It is impossible for a 16:9 movie to use the full 3:2 sensor. But we regard it as full sensor readout as long as the full width is used.
2017-9-26
Sebb
DJI_camera Posted at 2017-9-26 01:54
thank you for clearing that up!
I just saw RX100m4/5 also have full readout. I did not expect that to be the case either - quite incredible.
how about higher fps modes, e.g. 1080p120?
I havent tested it on P4pro, but the Rx100m4 has really clean 120fps for such a small camera -> from last weekend
either way - hats off to you guys implementing that sensor in this platform .. i m impressed every time i view my flight footage, especially when comparing to earlier Phantoms and Mavic.
2017-9-26
Dingoz
Surprisingly a 4K frame grab from P4A/P4P with a fast shutter is almost exactly the same in regards to detail and sharpness as an out of camera JPG with all profile settings equal and drone stationary/hovering.
2017-9-27
Dingoz
The P4A/P4P 4K frame is actually a crop of the 5470 sensor pixels after lens correction has been applied. The 4K frame is taken from about a 13-14MP crop of the full 20mp sensor. It is not down scaled from the sensor width of 5470 (it is lens corrected and then cropped from the middle section of the corrected image). So yes the video is using the full sensor (not a cropped sensor readout) but it is not scaling that whole sensor image down to get 4K (just taking a square pixel 4K crop of the 5470 after lens correction).
2017-9-27
Dingoz
My personal tests... settings: Normal and Soft (-1+0+0)
2017-9-27
Dingoz
Note just my theory. Really wanted to find which mode would work best for my needs. But this is only half the picture. Another test needs to be done for detail while moving (does 4K retain the detail vs 1920 once moving across a surface or detailed scenes) and does H265 afford more bit rate / detail over H264 in such cases (in other words is using H265 effectively 2x or 1.5x the bit rate of H264 when both at 100Mbps.
4096: Unless dimension is required, has no advantage in post (panning) as its not using wider sensor crop. Horizontal field of view is the same as 3840 but less vertical FOV. Less bit quality vs 3840.
3840: For a stationary hover scene like in this test (3m height and subjects from 10m to infinity) 3840 produces the best quality image and FOV overall @ 24/30
2720-1920: All modes are taken from about the 4K resolution (or from about a 13-14MP or less crop of the lens corrected frame off the 20mp sensor). Lower resolutions than 4K are scaled down (but not well IMO). More aliasing is introduced with each downscale in size (over sharpening effect in resizing down). The 3840 footage down scaled in PP CC onto a 1920 timeline looks much cleaner (anti aliasing) than native 1920x1080. Detail is roughly the same to my eyes on monitor or 4K TV. To make the 3840 look as sharp and aliased as the native 1920 footage requires +50 sharpening in Lumetri (and it still looks better than native but not by much - both start to show aliasing).
2017-9-27
Dingoz
DJI: A sensor crop mode would be nice also if it makes 60fps/120fps easier to work with rather than using the full sensor width to start with. An option in go4 to use crop or full sensor would be prefect. Also I do not understand why it can process 4K at 30fps well but can not process  1920 @ 60/120 well. Guess it must have some limitation in the process or can at least 1920 60gfps be improved upon (old GoPro Hero 3 can do 1920 @ 60 so surely my phantom can so the same without the skipping/binning or whatever is going on to make it so jaggy and blurry
2017-9-27
Sebb
Dingoz Posted at 2017-9-27 04:22
4096: Unless dimensions is required has no advantage in post (panning) as its not using wider sensor crop. Horizontal field of view is the same as 3840 but less vertical FOV. Less bit quality vs 3840.
very interestinig, thanks for sharing your test
couple thoughts
just to confirm: you re saying the c4k is basically 4k lettboxed and repacked at c4k resolution? of course i was expecting to 'see' a bit more... but then cropping 4K into c4K would be more or less identical.
i ve managed to get an opinion from wolfcrow on youtube about h.265 vs. h.264. he maintains that
- you really only benefit at low bitrates. where h.264 will break down, h.265 will still work. but 100Mbps  is a decent amount for a clean h.264 picture, therefore not much to be gained.
- h.265 compresses colors far more than h.264, therefore could result in banding and be even less robust in post than 8bit as is
- he would never use it, even on GH5. i hope i did not misquote his reasoning,,
Best
Sebb
2017-9-27
Dingoz
Sebb Posted at 2017-9-27 04:37
couple thoughts
Yes. It's letter boxed. Same effect as taking a larger original image in LR and applying a 4096x2160 vs 3840x2160 aspect ratio crop (horizontal FOV is almost the same but vertical FOV is a fraction more in 4K vs C4K. It also 'appears' that C4K is ever so slightly scaled up vs 4K or is the 4K ever so slighly scaled down more than C4K (could be wrong on this part).
2017-9-27
Steve Slechta
Flight distance : 31276 ft
Dingoz,
Thanks for posting that table!  Good stuff. I tend to like using H.264 more often on max resolution/30fps.  I do like to use H.265 and 60fps when I am moving around fast. That extra frame rate helps, though I do notice the slight color degradation.
Steve
Flight distance : 5852
Flight distance + Litchi: 72741
2017-09-24 - Breezy Island Flight
2017-9-27
Dingoz
For those interested this is how the video and images are processed into final outputs (approximately):
2017-9-27
Dingoz
Without Text Overlays
2017-9-27
Dingoz
Original 20MP sensor + lens output (Raw)
2017-9-27
12Next >
