Sebb
Flight distance : 498199 ft
charlesetischer Posted at 2017-9-18 05:59
The sensor of P4P has about 5470 pixels horizontally and the 4K video is down-scaled from the 5.4K RAW, thus making it sharper and less noisy than directly cropping a 4K window on the sensor.
Unlike 4K 30fps which has square pixels, the 4K 60fps footage is generated from 5.4K RAW with rectangular logical pixels. This technique allows to make full use of the same area of the sensor as that in 4K 30fps mode and keep the full FOV, without sacrificing dynamic range (compared to 4K windowed readout). It is beyond the performance limit of the sensor to readout 5.4K square pixels at a rate of 60fps.
i m not sure i understand fully what you re describing, however we do know that
- sensor can readout full resolution (20.2MP) at maximum 25fps = using all pixels
- sensor can readout cinema 4K resolution (9MP) at maximum 60fps = using partial scan
AFAIK actual framerate limitations of the camera are always introduced by the picture processer - the component that handles RAW uncompressed data frames and encodes them into compressed frames at a certain bitrate, encapsulated into a container. The RX100 m4/m5 for example cannot produce 4K60 frames, despite the sensor having such a readout mode. The Bionx processor can only effectively handle 30fps and already overheats after 5min as it is.
regarding different image quality, I highly doubt that 24/30fps video is using full readout mode (which doesnt even do 30fps), and only 60fps uses partial scan mode.
Today only few consumer cameras actually do 4K with full readout, since it requires siginificant processing. and since it is a premium feature, it is immediately included into marketing. See for example A6500 "4K movie recording with full pixel readout/no pixel binning". We dont see this with P4pro. RX100 also lack it which is expected at this price point.
having said that, all 4K modes with P4pro come from 9MP / 4.5K readout which is partial scan which has to be enlarged again, hence softer image. My assumption then is that 24/30fps can be compiled at full quality into quite clean 4K, while 60fps sacrifices yet additional pixels or lines, resulting in noticably softer footage.
not sure where you got your information, but please share any additional insights.
sorry for long post
