DJI Thor
Flight distance : 13602 ft
Gain settings are under the Advance setting of MC settings. Parameters under Basic Gain indicate how far an aircraft reacts to the remote controller’s command. A greater value indicates a faster response speed and an agile movement. If the values of Gain are too small, the aircraft cannot respond to remote controller’s command swiftly. If the values of Gain are too great, the aircraft may shake. It's not recommended to adjust it if the pilot is not very familiar with the operations. The answer to this question, you can check the sensitive setting for brake first, the other is that don't move the drone that fast. |
