Mark The Droner
Flight distance : 2917 ft
We assume you have previously chosen RTH as fail safe.
If you're in ATTI mode because you chose it, you STILL HAVE GPS. But your AC will ignore it unless it needs to RTH. If you lose control, it will happily fly home even while your controller is in ATTI. If you regain the control signal, it will still continue home even if you're in ATTI. You'd have to cancel RTH to make it stop coming home.
If you're in ATTI mode because you lost your compass, you STILL HAVE GPS, but unfortunately, if you lose control signal, the AC doesn't know which direction to fly home even though it knows where it is and it knows where home is. For example, it may know home is south, but it doesn't know where south is. It may try to fly home though. But it may fly in the wrong direction.
If you're in ATTI mode because you lost GPS, you have no GPS. No RTH.
As stated above, it is a mistake to calibrate your compass before every flight.
