nopedafu
Flight distance : 6312 ft
I've asked about video problems before and stupidly didn't update my notes. If I remember correctly since I'm using a PC it should be set to MP4 not MOV, is that correct? Also things look jumpy not smooth and I was told to reduce the video size which I did and things smoothed out, but then I crashed the drone and had it repaired and think some settings got changed because it's jumpy again. Will try 720P 1280x720 48fps. My question with this post is about the number of fps. Would reducing it from 60fps to 48fps make it likely to be smoother or more jumpy/choppy? How about lower than that?
Thank you for any help trying to understand this relationship!
David
