Geebax
Mark The Droner Posted at 2017-9-16 03:02
This is not correct either. What you apparently meant to say is there WERE (past tense) two specs being published. We'd have to go back to spring 2015 to prove that. But as you can see from the outdated ads I found in the OP, there is no listing that shows two specs. So I am certain you are mistaken.
It's my understanding that lightbridge, by its nature, is generally equal in distance whether it's control or FPV/telemetry, because they are both using the favorable 2.4 ghz freq, and they are both a one-way signal in the sense that there is no cumbersome checksum as there is in a wifi signal. For example, by buddy in Iowa flew his P3P 19.4 miles and landed it a field with full FPV and control. That's not to say one signal may not drop out while the other is connected or that the FPV wouldn't be inclined to drop out first due to its complexity. But there are certainly not two distinct specifications for the control signal and the FPV signal.
There were two specs, the return video spec is the one published on the side of the box, and in advertising, but the on-line manual of the time had a different spec called simply 'range' and it referred to the range of the control system, which was always greater than the range of the return video.
The term Lightbridge only referred to the return video channel, the control signal was not Lightbridge, nor was it WiFi, it was simply a bi-directional radio signal, much the same as the radio channel employed by other RC aircraft.
