DJI ASSISTANT DIFFERENCES
2608 12 2017-9-15
Cinefilms
Flight distance : 118829 ft
Dominican Republic
Hi All,
Quick question: Can you use the DJI Assistant Application (IOS) for Phantom 4 Pro to upgrade the Phantom 4!?.....Or does the P4 has to be upgraded with it's of Assistant App!?!?
2017-9-15
Tmygun
Flight distance : 2972497 ft
The DJI Assistant works across all platforms.   Phantom 4, 4 Pro &+, Phantom 4 Advanced, Mavic...etc.
2017-9-15
DJI Susan
I would recommend you to download the corresponding DJI Assistant 2 under Phantom 4 page.
2017-9-15
Cinefilms
Dominican Republic
DJI Susan Posted at 2017-9-15 19:20
so....it's different for each model!?
2017-9-16
BagoDJIoperator
Flight distance : 1077608 ft
Cinefilms Posted at 2017-9-16 07:59
Its not, its the same model for all
2017-9-16
Cinefilms
Dominican Republic
so....PLEASE EXPLAIN THIS:
1) FOR PHANTOM 4 PRO: DJI Assistant 2 v1.1.2-2 / 2017-06-19 (http://www.dji.com/phantom-4-pro/info#downloads)
2) FOR PHANTOM 4: DJI Assistant 2 v1.1.6 / 2017-09-15 (http://www.dji.com/phantom-4/info#downloads)
Again, Is there a difference between these 2 versions and also will this affect the drones if i don't use the one suggested by DJI!?.....Might this be the cause of so many issues with firmware updates!?!?
2017-9-16
Jenee 2
Flight distance : 7852129 ft
Cinefilms Posted at 2017-9-16 18:47
Well I am glad you brought this up because I have a Mavic and a Phantom 4 Pro and just assumed the Assistant 2 software was the same but it is a different version.
Mavic is v 1.1.6
P4 Pro is v1.1.2-2
I guess I will have to install both versions.
2017-9-16
15matjan
Flight distance : 1158258 ft
Very interesting observation, let's see what explains DJI with regard to the differences.
2017-9-16
hdlou94
Flight distance : 753163 ft
Hello, I have been waiting for some sort of resolution to my issues after the last upgrade, I am having difficulty flying over 1000 ft away from me , were i was able to fly well over a mile, i have uninstalled and reinstalled the software twice, calibrated and re calibrated the drone. any advice?
2017-9-17
Aardvark
Flight distance : 384432 ft
I just use the latest version V1.1.6. DJI just seem a little slow in rolling it out across the download pages for each model. For those that need any detail it is given in the release notes Here. These release notes also show detail of previous versions.
2017-9-17
DJI Susan
hdlou94 Posted at 2017-9-17 03:14
What's current firmware of aircraft and controller? Please try to adjust the antenna and see whether it helps.
2017-9-20
hdlou94
DJI Susan Posted at 2017-9-20 03:33
https://youtu.be/P7M9JtfVwQE
2017-9-24
James Whenman
Flight distance : 426375 ft
I live in a residential neighborhood with lots of interference. I can only get about 1000 feet away before I lose signal lock. That auto RTH worked great.
2017-9-25
