Don3221
Flight distance : 579669 ft
First open the latch on the CS bracket. Set the piece that mounts on the CS off to the side for now. On the other piece, unscrew the thumbscrews on the bracket. Then open the grips on the RC and place the piece that you just unscrewed inside the grips with the screw holes pointing out through the slots in the bottom of the grips. Now close the grips on the RC. Take the piece with the thumbscrews and line up the holes in the slots of the grip with the screws and tighten the thumbscrews into the grip. Make sure before tightining screws that the latch side is up. Attach the piece that you set aside onto the bottom of the CS. Place the CS with mount attached to the bracket hanging off the bottom of the RC and close the latch. Plug the USB into the bottom of the RC. Turn on the CS and go into the settings and push the flip screen icon. Now you are ready to go. |
