fansebb99a6e
Flight distance : 1276 ft
Hello,
I thought I would try the forum as DJI support has gotten me nowhere.
Updated dji go app.
Could no longer use that app, had to download dji go 4.
Prompted to upgrade RC. Upgraded RC.
Aircraft status: no image transmision
gimbal status: gimbal disconnected
Tried updating app through assistant 2 as the dji go 4 app did not promt to update.
Update failed after download 100%.
Reset to factory default in assistant 2 and tried update agian. Update failed again.
Have deleted and redownloaded assistant and dji go 4 app.
There does not seem to be any physical damage to the gimbal or its connectors. One thing to note though is that sometimes when I power up the aircraft to troubleshoot, the gimbal hangs limp after it does it's booting up gyrations.
I read that reformatting the sd card could fix the issue but dji go 4 does not even recognize that there is a card in the aircraft.
I have tried to upgrade firmware through the dji 4 app by holding down the three bars on the top right corner of the app but the app only recognizes the RC firmware and not the aircraft.
I am able to launch the aircraft but cannot see an image transmision nor can I record onto sd card.
This all started about two months ago and as I don't have about three hours every day to deal with this issue, I decided to just wait for an update to the app or to something that might fix this issue.
...The update came...but still no image transmission.
I hope that somebody might be able to shed some light on this issue for me.
Thank you for at least taking the time to read this.
