DJI Thor
Flight distance : 13602 ft
Thank you. Will help to have a check into it. And the Main Controller Setting will follow the drone, and if you had set the max flight altitude, it will not change when you change another mobile device. But firmware upgrade might reset the settings, you can have a check if there is a need after upgrading. |
