Superdave1
I crashed my P4P a couple of months ago. During my rebuild I damaged the main control board, I purchased another one along with a Yaw arm and Yaw motor. The P4P went together without a problem.
My first flight showed a warning " Downward Vision Sensor Calibration Error ", " Vision System Recalibration Required ".
I go through the calibration step on the controller, Calibration failed. It said to use the DJI Assistant 2 to complete the calibration.
With every attempt to calibrate using the Assistant 2, I cannot get past the tutoring steps, at the end it will tell me to "reboot aircraft", I do this with the same result, never making it to the actual calibration steps and you cannot skip the tutoral and go straight to the calibration.
Anyone had this issue?
Do I still have a damaged part?
