tonyboyle
There isn't enough trim on the tilt to fix how out it is. I think the worst it has been is 14 degrees out, which I can only correct to about 8 degrees with the trim.
I've tried the center function with the remote, I've tried calibrating multiple times, the trim, the only thing that works is slightly back balancing the camera on the tilt axis, but then as I said the motors are then constantly working.
It knows where 0 is, and it can get there as during calibration it sits perfectly level, it just refuses to do so under normal working conditions! Its so frustrating!
I don't have the Ronin on me at the moment, but it was fully updated with firmware/software last week. Are these numbers likely to be different? I'll have to get it out when I get in if these numbers mean anything more than what software/firmware I'm running.
