RicardoGray
Flight distance : 4356421 ft
I personally have my EXP set to .25 across all three, but I like things softened up a bit. I also changed my sensitivity on the brake to 80%, which seemed to help a lot. I never liked it when you let off the stick and your aircraft stops real hard. Again I like things a little smoother, but you have to make sure you don't get yourself in trouble too. Make small changes and try them out. Get in an open area away from everything and play around with it before you get into or around buildings, trees, etc. and discover your stick movements don't react like you were used to. Making some small changes will definitely make for smoother videos when panning and such in my opinion. |
