Two green solid lights on battery
7095 13 2017-9-17
fansd62e692a
Flight distance : 33960 ft
I have a battery that has two solid green lights in the middle of the four lights.  My Spark will not power up!  I put the battery on the charger and that didn't work.  I've tried to hook it up to the DJI Assistant but the Spark needs to power up to make the connection.  It looks to be some type of firmware update but if I can't get the Spark to power up I'm out of luck.  Suggestions?
2017-9-17
Rawsome
Flight distance : 230827 ft
How did the green lights appear? Out of nowhere or after a firmware update?
Do you have the 3 dock charging bay, if so you could try to flash the FW with that.
2017-9-17
Anuvis
Flight distance : 1976736 ft
Greece
Rawsome Posted at 2017-9-17 08:45
How can you do it?
2017-9-17
fansd62e692a
I think it happened on a firmware update.  I do have the three dock charging station.
2017-9-17
S-e-ven
Flight distance : 5922034 ft
Thailand
Isn't that the LED Signal during the firmware update? 2 middle LED on?
2017-9-17
Rawsome
It appears I was mistaken, you can't use the hub.
The FW update can take quiet some time, did you interrupt the process ?(I.e stuck at 98%)
If there is no other solution, I would send it in to DJI.
2017-9-17
ZhinGket
Flight distance : 111565 ft
Happened to me during firmware update, I sent my two batteries to DJI for replacement
2017-9-17
DJI Diana
Flight distance : 2408 ft
If you can power up the drone with this battery, you can try to re-upgrade the drone. If the spark will not power up with this battery, please contact the Support to start a case, send the battery in for diagnosis. http://www.dji.com/support
2017-9-17
HereForTheBeer
Flight distance : 5381368 ft
yes this is during firmware updates...  while its updating dont bother the drone or battery!   the battery was being updated and got interrupted if its stuck on 2 LEDs..  not uncommon or unheard of for updates to stick for 10 minutes or more on like 95% or 70% just not move for longest time then suddenly its done..  just devote an hour to the updates...
2017-9-17
DJI Elektra
HereForTheBeer Posted at 2017-9-17 20:01
Please follow Diana's advice and put your battery back first. Your drone will turn on automatically and you can re-upgrade your battery then. Any question, please inform us. Thanks.
2017-9-17
HereForTheBeer
DJI Elektra Posted at 2017-9-17 20:30
nooooo..... im not having any issues i'm just responding to the user with the issue.
2017-9-17
A.D. Lim
Philippines
did you get a fix for this.. same problem.. dji saying that i cant get arepair for this problem.
2018-4-30
A.D. Lim
Philippines
A.D. Lim Posted at 2018-4-30 22:38
Ellen Feng (Support)
5月1日 CST11:50
Dear Arnold,
Thank you for contacting DJI.
We are deeply sorry to hear the issue. Actually, there is no repair service for a battery as there is all liquor inside, for safety concern.
A battery enjoys 6-month warranty and if it is out of the period, we are afraid that you can consider to purchase a new one. Thanks for your kindly understanding.
Please feel free to contact us if you have any further questions, have a nice day.
Best Regards
Ellen
DJI Technical Support
Website: http://www.dji.com/support
2018-4-30
A.D. Lim
Philippines
A.D. Lim Posted at 2018-4-30 22:39
5月1日 CST11:50
What??? there is liquor inside the battery?... or maybe there is liquor inside your body you drunkard!!!!
2018-4-30
