Labroides
Flight distance : 9991457 ft
GeeDee Posted at 2017-9-24 07:31
Thanks everyone, I already recallbrated it,, no warnings or bad cells...I am watching it closely .. I suspect it is a combination of flying with half empty battery on a cold day from now on will fully charge before take off
I suspect it is a combination of flying with half empty battery on a cold day from now on will fully charge before take off .
If you look at your recorded flight data as recommended in post #3, you'll see the voltage for each cell in your battery for every 1/10th of a second during the flight.
From what you've said, it sounds like you were running a very low battery and the cell voltages must have dropped perilously close to 3.3V which will trigger a critically low battery condition and force your drone to land.
NEVER launch with a partially discharged battery, particularly in cold conditions.
The battery % indicator will give you a false reading.
That's just asking for trouble.
Only fly with a fully charged battery. |
