Aardvark
Flight distance : 384432 ft
68cst Posted at 2017-9-18 04:05
I was thinking that may be it so i went to roll back the RC to 1.8 but that would immediately fail. Tried the 1.6 and it rolled back to 1.6 fine but still no connection to AC. Will try the 1.8 again this evening but not sure why the tiny red light on the drone does not illuminate any color, getting the flashing yellow from the two rear (i think) blinking lights. I hooked the AC to the computer and downloaded the latest DJI assistant 2 and tried the upgrade, the upgrade will download to 100% then about 3 min later will get a message update failed. used the restore factory default and it would go to 100% and i would select complete and reboot. when going back to DJI assistant 2 it would show the current version v01.02.602 attempted to run the update, it would download 100 % but 3 min later "update failed" not sure if its the AC or the RC at this point.
When I power up my aircraft only (indoors, no GPS/GLONASS signal), after the aircraft has initialised the LED beside the SD card slot glows Orange. That is with latest build and formatted SD card in slot (it also glows orange when no SD card installed).
You could perhaps try updating again with SD card removed, in case it is faulty or badly formatted and causing problems.
When aircraft only powered up indoors I would expect to see two front arm LEDs red (these are always red, 'navigation' lights), the two rear arm lights I would expect to see fast flashing yellow (remote controller signal lost (it's not turned on yet).
When RC is switched on and the left hand LED on RC turns green (which means it's talking to aircraft) the rear arm LEDs change to green, flashing twice about every 2 seconds. This indicates that it is ready to fly using VPS positioning (remember indoors so no GPS/GLONASS). The LED beside SD card slot also turns green, indicating the aircraft is talking to the RC.
I would focus first on being confident that the aircraft firmware has updated. So would try again using V1.1.6 of DJI Assistant 2 (the latest), and again with SD removed if first attempt fails.
