Epicdoom
Flight distance : 340620 ft
I get the same message I just ignore it you can see if the firmware updated successfully by removing your SD card and put it in the laptop or computer open up the files you will see a file called P3XW_FW_RESULT_AB click it opened and look at the top entry it will be something like this what you want to see is the word success as a result
========== 2014.01.01 00:00:09 remo-con disconnect======
Packet: P3XW_FW_V01.05.0040.bin
Upgrading ...
Result: Success.
You can look in the about section of the DJIgo app and see the version of FW that's installed also |
