Barney Rubbel
This has been my experience: When the Wifi is still connected, but the control signal is lost, the message you get is "Control Signal Lost" which will be followed by the "Coming Home" message should the control signal not recover its connection. When the Wifi connection breaks, you no longer get the information fed back to you as to altitude, distance, speed, etc. and your picture normally will just freeze. You will still have control of the Phantom. Unless, of course both signals are lost, at which point you just cross your fingers and hope that it goes into RTH mode. I have been lucky and not lost either (Both are P2V+, but one is version1 and the other version 3) of my Phantoms yet.
In my humble opinion: Some people say you should never turn off your controller until it is a last resort. I feel that it adds a sense of security to know that their investment will come home should it become unable to communicate with the controller, so recommend that new flyers go out and try it to be sure that it is working properly. RTH mode is RTH mode whether it is due to issues, or manually induced. Just know what your RTH altitude is set, hover the Phantom 100-200 meters or feet away from you and shut off the controller and see if it does what it is supposed to do. It should ascend to the set RTH altitude, fly over to its "Home" position (at the RTH altitude), wait a couple of seconds to see if it can find its signal, and then land should it not find the control signal. Barney |
