DJI-Mark Posted at 2017-9-20 09:48
Have any of you checked the product page of the Phantom you are flying? That is the best place for release notes. You can get more information on what the latest firmware is if you go to the product page of the aircraft you are flying.
Hi Mark
The problem is all the changes you omit from the release notes. Please point me to the release notes telling us that:
Safe return to home toggle removed..
HDMI overlay toggle removed.
Gimbal, some adjustments removed.
Map handling - old bugs re-introduced.
Removed firmware downgrade possibility.
Transmit power reduced. - or as i think is actually happening, for each refresh of FW the transmit power will be reduced by x from what ever value it has reached so far.
Also i believe that some release notes should have stated that: In order to keep better track of NFZ handling some processing power has moved from other GPS routines to the NFZ processing, unstable GPS precision / hoovering may be accepted. - or what ever is going on!
