LouisP
Flight distance : 41952 ft
YOu may have an SD card issue.. But in my first flights I was also very confused about the camera. If the drone is set to take video and you press the still picture button, the first press of the button switches it to picture mode then a second press takes a picture. If it is in still picture mode, the first press of the record button switches it to video mode and it takes a second press to start recording. The red lights on the front of the drone are OFF when recording video and ON when not recording. You can't switch to picture mode while it is recording video... I assumed that red lights on meant recording, so I would turn the lights off and try to take a still... it would not work.. I found it confusing, but after a bit I got used to it.. Play with the camera on the ground and figure it out. Try a different SD card if you can.
