DJI Thor
Flight distance : 13602 ft
This is a flight distance issue. Flight distance sometimes relates to the flight environment, we would suggest that you fly the drone in an open wide area. Check the position of the antennas for the remote controller. Distance should be greater than height during flight, and please make sure the remote controller’s antennas are positioned parallel to and are pointed towards the aircraft, you can refer to the picture below. Still, use a mobile device with a strong performance. If the issue persists, please help to confirm if there is an impact damage before and the antennas are broken, you can send the drone back for an overall check.
