Cetacean
Flight distance : 2528264 ft
Aloha Nelson,
Sometimes there are problems with linking between the Phantom and the device and Remote Controller. You would have to disconnect completely and then try a complete new linking. If you do not do this the problem can remain in the system and it will never be able to link again to the same device until it is completely linked again.
If a complete re-linking does not work, you will have to remove the DJI GO 4 app completely from the device, and do a fresh install after a shut down for at least a minute and then a restart. You cannot allow just the new parts of the software to be reinstalled. The whole app has to be replaced. Any leftover parts of the software can come back to affect the new install and then your problem will come back.
The reason I am recommending this drastic effort is because the two devices that do not link, each have the app on them and they are powerful enough to handle the app with ease. Therefore the problem has to do with the linking, the download of the app or the installation of the app. If you want to use these devices (and a fresh re-linking does not work), you will have to completely erase the app and after a complete shutdown for a minute or more, start up the device again and download the app again and do a fresh install. BTW, it is also important to do a new download of the app also. You have to get rid of all the previous software so it does not interfere with the new install.
Let me know how it turns out.
Aloha and Drone On! |
