Irate Retro
Yikes, that looks horrible! The whole gimbal is going nuts it would seem.
I'm assuming you don't have any aftermarket crap installed on your drone.. no guards, filters, etc. (If so, take them off.) Examine the gimbal for anything that would interfere with movement, or anything that seems out of place. (I don't have a 3 series so I cannot be of more help there.)
Does this only happen when you are out flying, or can you leave it sitting on a table indoors and get the same result? It's rather strange how it seemed perfectly fine during takeoff and climbout. It was only when you moved the gimbal downwards after the left turn at altitude that things started going crazy. Is that always how it is? Everything's fine until your first gimbal movement? (Try a flight without moving the gimbal at all.) Or does it seem like it only does this in the wind at altitude regardless of whether you even touch the gimbal tilt control? Any unusual noises from the gimbal when you turn on the aircraft in a quiet place and move the gimbal around?
Any errors logged when you fly with the DJI Go app? I'm assuming you have already done a gimbal calibration (if the P3SE offers that) in DJI Go. |
