Problems with wrong Repair Quotation
571 8 2017-9-19
fans6db15f52
Flight distance : 197 ft
Hi,
I am having a problem with the European support center in the Netherlands. They have sent me a quotation with parts not related at all with the reason for sending the Mavic to them and are unable to provide answers about their mistake. I am very upset with such an unprofessional behaviour. What can I do to solve the issue?
2017-9-19
Sorry to read on this, would you please post the case number here? We will help to look into and feedback to local repair team for double damage evaluation, thank you.
2017-9-19
ALABAMA
Flight distance : 10442687 ft
Sometimes repair finds a lot of things wrong that you can't see.  Many things internally that can't be seen.
2017-9-19
fans6db15f52
DJI Mindy Posted at 2017-9-19 04:02
Hello,
sure, the case number is CAS-946174-Z2M1K2.
It was sent for a gimbal motor overloaded error, which is a typical defect on many units. My Mavic has some minor scratches on the lower shell due to frequent landing on rocky terrain but has never suffered a crash. Despite this they are not willing to fix the Mavic under warranty.
In their quotation no parts related to the gimbal problem were mentioned so it was assumed that I would receive back the same Mavic with the gimbal problem. Only today they specified that they will replace the craft, so at least there should be no gimbal problem. However, I find very odd that this defect is not covered by the warranty, since in many other units the craft has been replaced or fixed at no cost.
2017-9-19
DJI-Mark
fans6db15f52 Posted at 2017-9-19 08:27
Hello,
Hi, thank you for the information. I have an associate looking up your repair information. As I find the answer, I will post that here.
2017-9-19
DJI-Mark
The reason for the non warranty repaired is that it was determined to be crash damages on your aircraft. Do you have DJI Care?
2017-9-19
fans6db15f52
DJI-Mark Posted at 2017-9-19 08:57
No I don't have DJI Care and there has been no crashes on the Mavic, the marks are there because of landing on rocky terrain and the Mavic has way too short legs.
2017-9-20
fans6db15f52
and btw, if you look at your website there is no DJI care available for Mavic
DJI care products
2017-9-20
fans6db15f52 Posted at 2017-9-20 02:04
DJI care products
The damage assessment shows middle and lower shell damaged, camera pitch axis folding cover and one propeller damaged. If you insist in repairing gimbal only, we will feedback to local team to see if it is OK.
Besides, Mavic has DJI Care Refresh service, please check more info here.
2017-9-20
