HereForTheBeer
Flight distance : 5381368 ft
the update added compatibility for new props. likely will adjust itself accordingly on start up. the control and ESC system is fairly smart and will likely calibrate at spin up stages based on resistance and balance and stuff.
what im wondering is if the new props have any comprimises elsewhere like what is the bite (angle) and will it produce the same lift? are the the same size? etc etc.. usually you dont want to increase the prop size, they likely are overall same length, and since the winglet tips are about 1/4 the total length, what else changed?
