CUTIGER Posted at 2017-9-20 04:53
From the very first flight the signal from the drone to the iPad would flicker badly. I tried switching cables and iPads with my phantom 4 pro and nothing stopped the flickering. The pictures to the SD card were good, so I tried to just live with the flicker. Then one day the screen went completely black and I could not return the drone home. It was about dark, so I had to wait until the next day to try to find it. As I said earlier I had to use the long and lat coord. to find it. I made several calls to DJI support and it was determined that the drone was never sending the appropriate video signal back to the controller. I was told this would be covered under warranty. I did not keep detailed notes on who and when I talked to because I thought DJI would keep detailed information in tech support. I do know that on one call I spoke with a technician named Mike who had me try some updates (non of which solved the problem). It was after I spoke with Mike that on another lengthy call I was told to return the drone for warranty repair. Hope this is helpful to you.
Thanks for your quick update.
From the damage assessment, I've seen the camera main board needs to be replaced, which may be the reason of image transmission issue. But I'm not sure, maybe the crash caused damaged camera main board.
When you find the drone, it was landing normally on the ground or crashed?
Since the motors and landing gear also got damaged, they usually relate to crash.
As for the warranty promise by our Support, you have our sincere apologize, we will take it very seriously and do more training to improve our customer service.
