ACW
Flight distance : 13877205 ft
Peterev Posted at 2017-9-24 14:51
Thanks, yes I have. The fpv setting is quite different from follow, the gimbal is fine most of the time, it just drifts out of level when yawing and rolling. I didn't get out this weekend to try the refreshed firmware but will be tomorrow..
The main cause of this is excessive wind speeds which can be exacerbated by adding third party accessories to the drone such as landing gear, ND filters and prop guards/props not made/tested by DJI. Other influences are caused by electromagnetic interference tampering with the compass (even fields can have underground metal pipes and electricity cables etc) and the IMU being off + firmware issues. Try changing your flight location after calibrating the IMU and refreshing the firmware at home before heading out and ensure that you have nothing attached to the quad. If, after doing this, you are still experiencing the same problems then you may have a serious fault with the drone and I would suggest creating a label with DJI for a diagnostic evaluation and potential repair/replacement - hopefully under warranty. |
