spark malfunction in flight
2706 36 2017-9-20
userc2f3482696
Flight distance : 3529009 ft
Cyprus
Today i had a strange problem with my spark..in about 1:45 minutes during 3rd flight at the same location,spark had lost all satelites,went into atti mode,and the first warning appeard on the screen.."Current RTH route will pass a No-Fly zone..."then the second..warning: Compass error..then the 3rd: in flight,working,IMU encountersheading exception,please switch to atti mode if the craft behave abnormally..then the last one..: weak GPS signal positional accuracy may be compromised..and all those warnings appeard almost at the same time..it was windy..about 27 km/h,and the spark started drifting at the direction of the wind of course..but the strange thing is that i gave full stick to bring it back and i had no response from the spark..then i switched to sport mode and immediately responded and came back..i am experience pilot,i know how things work..this is not a usual compass error..the whole thing lasted for 2-4 second,and if i didn't switched to sport mode which i don't know if that saved the spark,it will crashed at a wall.. also in the first flight i checked the compass readings in 3 spots over the flight route and it was close to 50-60.. i don't know if uploading the black box will help Dji to figure out the problem..
2017-9-20
hallmark007
Flight distance : 9827923 ft
You said wind was at 27kph so pushing sticks it is not going to make up any ground if you trying to fight the wind.
You could upload your log to link below might give you a better understanding of what happened.
http://www.phantomhelp.com/LogViewer/Upload/
2017-9-20
jcwconsulting
Flight distance : 944236 ft
that sounds VERY SIMILAR to what recently happened w/mine! sent the Spark in for repair, & their diagnosis was a bad GPS receiver. i highly suggest you do the same. now following this thread w/great interest...
2017-9-20
userc2f3482696
Cyprus
hallmark007 Posted at 2017-9-20 08:25
Thank you for your help.. i know,but in gps mode was flying just fine..it's supposed to be faster in atti mode..
2017-9-20
userc2f3482696
Cyprus
jcwconsulting Posted at 2017-9-20 08:33
this is scary because if it is the gps reciever, it will happend again.. and i had 21 hours of flight in the spark with not a single problem before that..
2017-9-20
Oracle Miata
Flight distance : 3759829 ft
Honestly, that's a lot of wind to ask of the little Spark.  What height and distance where you at?
2017-9-20
userc2f3482696
Cyprus
Oracle Miata Posted at 2017-9-20 08:37
honestly..my iphone said that it was 27 km/h..but judging for what i felt,it was ok for the spark,maybe it was not 27km/h.. i got the first high wind velocity warning,and then went off.. i was close..13m height and 22m distance when this happened..
2017-9-20
Wachtberger
Flight distance : 261509 ft
Now this is a very interesting case with a very good desciption of what has happened and what was done! And definitely a case to be examined by DJI. Open a support ticket and upload all data to DJI for analysis would be my course of action.
2017-9-20
hallmark007
userc2f3482696 Posted at 2017-9-20 08:34
Well that’s true, you would be able to see how much progress you made if any in PH logs. Good job you managed to save it.
2017-9-20
Supong
Thailand
This is exactly what happened to many Spark since Mandatory update. Strong wind created another problem but not as describe here. The message “current Roth route will pass no fly zone” was initiated by false gps reading. The compass error, happened mid air was due to either hardware false, probably by high temperature inside Spark, probably you had been taking video all along 2 batteries, or from firmware error that caused false warning, The “IMU encounter...” was possible caused by same reason as the compass error, high temp or few error. In previous cases, after “IMU ...” message, Spark did not response to RC.
2017-9-20
Sparky_17
Flight distance : 62349 ft
should be interesting to find out what DJI has to say about the log.  Please submit your log to DJI for analysis.
2017-9-20
DJI Elektra
Please export the flight data of your drone and then upload it to dropbox. We will help you locate the problem. Thanks for support.
2017-9-20
starter-pilgrim
Flight distance : 61962 ft
Ukraine
Hi everybody.
2 days ago I had very similar flight problem, exactly same order of warnings and same behavior of Spark.
2017-9-20
DJI Elektra
starter-pilgrim Posted at 2017-9-20 19:34
Hi everybody.
Did you fly near the No-Fly Zone? Did your spark still work well now? Please export the flight data and upload to dropbox for us to analyze. Thanks.
2017-9-20
userc2f3482696
Cyprus
DJI Elektra Posted at 2017-9-20 18:54
this is the link for the flight log..https://drive.google.com/open?id=0B8u8Iv6XtT2dOHBIWUwzb3RyTlE
Also this is the link for the log viewer: https://app.airdata.com/main?fli ... amp;page_id=GENERAL
2017-9-21
starter-pilgrim
Ukraine
DJI Elektra Posted at 2017-9-20 23:48
I was faraway from any No-Fly Zone. After this accident I reset Spark to default factory settings and then reinstall last firmware. After this I flew one battery without any issue (on another place).
2017-9-21
userc2f3482696
Cyprus
Hi everybody.
hello..did your spark crashed?
2017-9-21
ZukySpark
Flight distance : 226066 ft
Portugal
Spark and his errors...software? Hardware? DJi solve it...
2017-9-21
jcwconsulting
userc2f3482696 Posted at 2017-9-20 08:37
correct - there have been several instances of 'Weak GPS Signal' & 'Exit-P GPS Mode' errors where the drones all (mis)behaved almost the same exact way. i'm wondering if there was a batch of faulty GPS receivers in one (or several) manufacturing runs
2017-9-21
starter-pilgrim
Ukraine
userc2f3482696 Posted at 2017-9-21 09:19
Yes and no. Spark tried to flyaway on high speed but caught small tree on the way.
2017-9-21
djiuser_XGmOaOo
Flight distance : 22382 ft
Brazil
Very similar to my case. DJI is investigating. :-(
2017-9-21
userc2f3482696
Cyprus
userc2f3482696 Posted at 2017-9-21 06:45
Also this is the link for the log viewer: https://app.airdata.com/main?flight=da75f25e74947f593a67393a3595533f&page_id=GENERAL
Also i made a screen recording the whole flight log from my phone.. here is the link :
2017-9-21
Outsider69
Flight distance : 25561 ft
I had exactly the same problem. Compass Error and immediately after that was the Spark out of control. He flew with high speed in the next three (no wind). Very dangerous for my family. Now the Spark stays since 12 days in the Repair-center in Netherlands. The support ignores completely the problem, didn't reads the Log-files and say no warranty, but you can pay 49.- € for a new one ( care Refresh). After my Veto I didn't received a qualified answer. I am desperately. I want go in one week in holydays and DJI leave out in the rain. Case number is CAS-965331-T5R9M2. Maybe a competent support staff read this. Please help me, please help me!!
2017-9-21
brian_b
From what Iʻm gathering from here and other threads where GPS goes haywire, should we all just go into Sport mode and high-tail it out to home when this malfunction happens? Iʻd attempted to practice in Atti mode for emergencies, but I donʻt know how to put it in that mode deliberately.
2017-9-21
DJI Elektra
Outsider69 Posted at 2017-9-21 15:44
I checked the case for you. The analysis showed that the accident was not caused by users and we will repair it for free.
Please notice that we sent you email about this or you can check your spam.
Please wait patiently and your spark will be sent back after repair. Thanks for your support.
2017-9-22
DJI Elektra
Thanks for your update. Can you export the complete data through DJI Assistant 2?
2017-9-22
DJI Elektra
starter-pilgrim Posted at 2017-9-21 09:04
Good to know there is no more issue. Please keep us updated if any problem exists again. Thanks.
2017-9-22
ACW
Flight distance : 13838848 ft
I noticed your RTH altitude was set at 50M on take off - were you connected to the remote via wireless WiFi or an OTG adaptor/cable?
2017-9-22
ACW
brian_b Posted at 2017-9-21 17:21
You can't on either the Spark or the Mavic.
2017-9-22
userc2f3482696
Cyprus
ACW Posted at 2017-9-22 02:18
i was connected with the controller,and from controller to my ipad mini 4 via wifi! yes,i always set the RTH altitude depending on my surrounding trees/buildings etc..
2017-9-22
userc2f3482696
Cyprus
Supong Posted at 2017-9-20 08:59
xm.. i had no idea.. i will not make any other flights then,until i hear from dji if it is safe to fly again or it needs to be sent in for repair/replacement! thank you very much for the info!!
2017-9-22
userc2f3482696
Cyprus
so probably wasn't the sport mode that saved my spark..i must have been lucky!!! :/
2017-9-22
userc2f3482696
Cyprus
after my incident, i thought that the sport mode saved my spark because instantly when i switched it, spark responded....now i have my doubts..maybe i was just lucky..
2017-9-22
userc2f3482696
Cyprus
DJI Elektra Posted at 2017-9-22 01:40
https://www.youtube.com/watch?v=ngEHdAlAh9A
This is the link for the flight data of spark: https://drive.google.com/open?id=0B8u8Iv6XtT2dQXNHa1p5NF9FVXM
2017-9-22
lauspark
Flight distance : 100541 ft
I had exactly the same problem as you today and for me unfortunately i have lost in a calm day, lose signal completely while in the sky, i think most like it landed in the water at the beach!! I have contact dji support and log my case, i have purchased dji care and i really hopefully they can do something about.
2017-12-26
lauspark
2017-12-26
Wachtberger
lauspark Posted at 2017-12-26 03:31
Very sorry to hear about your loss. If you wish to receive some feedback from other pilots on what might have happened you may upload your flightrecord here http://www.phantomhelp.com/LogViewer/Upload/ and share the link with us.
2017-12-26
