HereForTheBeer
Flight distance : 5381368 ft
ya no real maintenance needed..
just get a blower, i have a 150 PSi shop air compressor, for cleaning my mavic 150PSi shouldn't hurt anything but i turn off the compressor at 50 PSi and use a blower tip.. and spray out the vents... but you can use air cans or whatever if you want..
wipe cleaning: i suggest using micro fiber clothes and get them damp not soaking wet or dripping wet, just warm and moist and wipe it down... use separate micro fiber cloth for the glass camera lens so you dont transfer debris like sand and scuff up the glass lens..(you be amazed how easy it is for basically invisible sand caught in fibers to scuff the glass up forever)
check the arms and props for damage.. simple as it sounds.. shouldn't be any cracks or separation..
check motors hold the props and wiggle the motor, i found one of my motors was ever so slightly loose on the blade wiggled just smallest amount, the quick release plate wasn't tightened all the way down, i quickly fixed that, so that's on the list now to check..
check to make sure nothing is broken elsewhere like no prop cracks or missing prop teeth where it quick releases..
finally check all sensors, make sure clear or cleaned.. or at least enough that they are completely operations and dont have water spots on them or streaks or debris.. if they so, use a little bit of air to remove debris and clean the obstacle cameras/VPS cameras.. with microfiber cloth..
interval to do this: no set standard.. just as needed, or during preflight checks or every few months if otherwise maintained well..
