mavic pro platinum 8831 propellers on mavic pro
11123 16 2017-9-21
fans8882c16f
Can the "8831" propellers for the platimun version of the mavic be use on the mavic pro insted of the normal "8830" ? and does it have some advantege on the battery performance? and for last are the material differente or is you the aereodynamic shape that changes?
2017-9-21
Landjet
Flight distance : 61496 ft
Yes, the "8831" can be used om the MP and replace the "8830" props but you will not have the increased flight time. Batteries for both models are the same (outside of color). I can't speak for the material used, but would imagine it is the same. Only real difference is the shape - providing some noise reduction and a little more efficient lift.
2017-9-21
fans8882c16f
*or is just the aereodynamic* sorry for the typing error
2017-9-21
DocAraxá
Flight distance : 202283 ft
Brazil
It may help:
https://forum.dji.com/thread-110991-1-1.html
2017-9-21
fans8882c16f
Landjet Posted at 2017-9-21 02:23
thank you! by the way for the batteries i hope in the future dji will provide to increase the storage capacity in the same battery shell, so to have 2 in 1.
2017-9-21
fans8882c16f
DocAraxá Posted at 2017-9-21 05:32
It may help:
very useful, thanks!
2017-9-21
DocAraxá
Brazil
It is my pleasure!
2017-9-21
DJI Thor
Flight distance : 13602 ft
Yes, you can apply 8831 props to Mavic Pro, noise reduction and flight time are also enhanced when used with the Mavic Pro, but not as much as Mavic Pro  Platinum, please note that you need to update the latest firmware for the compatibility.
2017-9-21
fans8882c16f
DJI Thor Posted at 2017-9-21 20:11
Hi, I had a problem with that! i did the update, everything gone fine and in the end of it i shut down the drone untill the next morning and i dont know why there was still the old firmware and the app says " latest firmaware". i tried to unistall the dji go app but it didn't work. the intelligent fly mode are still the same and i check the drone firmware versione and its still the one before the 19th is there a way to let the drone find again the latest update? because i tried allready everything from the app. Thanks for help
2017-9-23
DJI Thor
fans8882c16f Posted at 2017-9-23 04:49
Just to verify, do you have more than one battery? If yes, it might be that you haven't updated the other batteries. For your case, I suggest trying to refresh the firmware via DJI Assistant 2, if the problem persists, please provide me with the screenshots of the prompt and the About on General Settings.
2017-9-27
ixyQeEdhN0p9
Costa Rica
DJI Thor Posted at 2017-9-27 02:55
Why would you need to update the firmware kn the first place???
2017-9-28
DJI Thor
ixyQeEdhN0p9 Posted at 2017-9-28 21:46
This is the basic troubleshooting, first to exclude the issue that is caused by firmware inconsistency.
2017-9-30
CoreyB10
Flight distance : 1665023 ft
Yes they are compatible and next stock due to be shipped 18 October as per reply from DJI Support this afternoon.
2017-10-5
SadMavic
Flight distance : 91132 ft
Why would you need a firmware update to use the new props?
2017-10-5
DJI Thor
SadMavic Posted at 2017-10-5 07:07
This is confirmed by the engineers. Please kindly update it for the optimal use of the low noise props.
2017-10-9
pixy
Flight distance : 2418684 ft
Japan
こんにちは。
8831を、MPで使用すると、約1分ほど ランタイムが増えました。(室内でホバリング)
電池も、旧型です。
騒音は、あまり変化は、感じません。
見た目が良いので、満足です。
因みに、MP.RC.crystalsky5.5は、全て 最新FWです。
2017-10-9
dancopter
Flight distance : 17901030 ft
United Arab Emirates
The 8331 props operate at lower RPM, so I guess the motor control needs to be adjusted.
2017-10-9
