Slow spark, wont go above 7mph
5141 10 2017-9-21
PascalG
Flight distance : 274327 ft
did two quick test flights this morning with my newly received spark (second one).  Only problem is that in a straight line, an in non sport mode, the spark wont go over 6.7mph. No problem in sports mode where it tops at over 30mph
Checked the settings,  beginner mode is off, no errror message.  All firmwware and app updated yesterday, imu, compass and controller calibrated as well.
Using RC via wifi, ios version of app
What am i missing?
2017-9-21
Cosmic Moto
Flight distance : 19534 ft
In P mode its limited to 6.7 mph because of the object avoidance.
I would say its working as it should but i am very new myself.
2017-9-21
Kloo Gee
Flight distance : 16783757 ft
That is working exactly as DJI designed it.  In normal GPS mode with full sensors enabled, 6.7 mph is tops.  You can disable the forward obstacle sensing, then its maximum speed will top out at 13.4 mph.  As you noted, Sports mode tops out at around 30mph.
Check out pg 9:    https://dl.djicdn.com/downloads/ ... ser+Manual+V1.4.pdf
2017-9-21
PascalG
Thanks. I just did a google search and that seem to be reason.  I had searched th forum before posting but the search engine isnt as good as a basic google.
I never used obstacle sensor on the first one and forgot to disable it on this one.
And to think i had re read the manual last night...
2017-9-21
Sparky_17
Flight distance : 62349 ft
Kloo Gee confirmed what I was about to respond.  As per design
2017-9-21
Kloo Gee
PascalG Posted at 2017-9-21 06:45
I've been through the manual a million different times and still find new nuggets in there I hadn't digested previously.
2017-9-21
JMR58
Flight distance : 627966 ft
Belgium
When you go to the controller settings in the DJi app and you tap on the top of the first window, there is a bar at the botom of the next window where you can change your speed, or is this just for the turnings?
Maybe something went wrong with this?, just trying to help..
2017-9-21
DJI Susan
I'm sorry that the forum's search is not that great. Please try "site:forum.dji.com <search term>" on Google.
2017-9-22
TomiToivonen
Flight distance : 722343 ft
Finland
Thanks JMR58.
I did upgrade all today and after that I had the same issue. Speed was about half way and drone was really slow.
2018-8-27
Jakab Gipsz
Hungary
Well yes .. Search is a kind of knowledge ...
http://lmgtfy.com/?q=DJI+Spark+flying+speeds
4. hit
2018-8-27
FlyMaine
Flight distance : 389482 ft
Kloo Gee Posted at 2017-9-21 06:41
Check out pg 9:    https://dl.djicdn.com/downloads/Spark/20170727/Spark+User+Manual+V1.4.pdf
Thanks so much, Kloo Gee. I’ve been wanting to get some extra speed without going into Sport Mode which is way too fast for me and now I know how to do it!
2018-8-27
