Nigel_
Flight distance : 388642 ft
fans61699a75 Posted at 2017-9-22 06:58
Thank you for aak the answers , but i am still doubting noe what to do. Just first have it lifted up and check all the movements , hover , left/right forward/backward like hallway has mentionned before , then check how drone behaves? If normal , no calibration . If prompted or crooked , then calibrate ? Is this the best thing to do?
Yes, and I expect it will fly normally, there is more risk in north west Iceland but most people have no problems.
If it does go out of control because of compass problems then it will probably start flying in circles, it will not crash unless it hits something tall, so:
1. you should increase height far enough that it can't hit anything.
2. switch to atti mode and fly it back manually - do not use RTH because this will not fly straight.
Practice using atti mode to fly back home manually before you travel, it can be difficult if there is wind. |
