lannes
Flight distance : 4465 ft
1) When connecting to the DJI Assistant 2 , the AC and RC need to be turned on for them to be recognised by the application also try using the micro USB port on the controller
2) When you are indoors , you cannot connect to the satellites that is why you are defaulting to "ATTI" mode
3) Have you updated the RC , https://dl.djicdn.com/downloads/ ... ntom+4+Pro+Plus.pdf,
get the zip file from here http://www.dji.com/phantom-4-pro/info#downloads
4) Have you tried using a IOS device instead of the built in screen to see if it works, haven't tried this myself, but again it might need to use the micro USB on the controller
