dji mavic pro firmware update
1982 14 2017-9-23
fans8882c16f
Hi, after i downloaded and installed the latest firmware update from the dji go app i turned off the drone because the processe was completed. i did not restarted the drone like the app asked because i was going to use it the day after anyway. the next morning i turn on the drone ad for surprise i did not found the new upadate but still the old one, I tried to check manually for the app but the status was "latest firmware" and the same is for dji assistant app for pc still says to me there is no update available yet and the old firmware is the last one, how to i risolve this problem? thanks for all for your help.
P.s. I allready tried to unstall dhe dji 4.0 app from my device and installing it back again and still it's says there are no latest firmware.
2017-9-23
fans8882c16f
the firmaware version is currect but the new features are not available, and it looks the same as the old version, sorry i did not express the problem correctly
2017-9-23
New firmware added Quickshot feature and Dynamic Home Point for Active Track Mode.
If you mean there is no Quickshot, may I know your APP version?
2017-9-23
QuadKid
Flight distance : 482349 ft
DJI Mindy Posted at 2017-9-23 06:29
Crystal Sky is still running D4 App 4.1.6, Are we going to get the latest update soon???
2017-9-23
fans8882c16f
app version is 4.1.9.
2017-9-23
fans8882c16f
I have taken some screenshots from my device ( ASUS ZENFONE 2 ZE550ML ) so i can be more clear about my problem. Shall I try to downgrade to factory settings and try to do the update again? thanks for your help
2017-9-24
$gambino$
Flight distance : 1563980 ft
U need the new app too! If you do a search on Google for "dji go 4 4.1.10 apk" u will find it. I have been playing with quick shots for the past two days works great with the new app
2017-9-24
DJI Thor
Flight distance : 13602 ft
Had replied on your new thread, please check.
2017-9-25
DJI Thor
QuadKid Posted at 2017-9-23 06:32
We will forward this need to the engineers, hope it supports the new functions, too.
2017-9-25
fans8882c16f Posted at 2017-9-24 06:52
Please refer to Gambino's suggest to update the APP as well, thanks.
2017-9-26
The APP built-in CrystalSky is optimized and different from APP in mobile device, but we will keep improving it to add more functions.
2017-9-26
Jos A
Flight distance : 73209 ft
https://apk.tools/details-dji-go-4-apk/
NEWEST DJI GO 4 1.10 ANDROID VERSION, NOT IN GOOGLE STORE YET!!! (NEW FLIGHTMODES)
2017-9-26
fans8882c16f
$gambino$ Posted at 2017-9-24 07:24
thanks you! i was just wondering what is the differece between the apk version and the google store one, are the same? do i risk having some issues? i only used google app app since now.... thank you for helping me clear my mind
2017-9-26
Jos A
fans8882c16f Posted at 2017-9-26 07:53
they are the same, in fact I flew a couple of times now.
2017-9-27
Jos A
https://forum.dji.com/thread-113562-5-1.html
read after post 175
2017-9-27
