As some have indicated, in a nutshell no The main reason, there are two 1) burn through in close and a small target like that will be lost in the noise and at a distance it may or may not be picked up, if so, it will likely be intermittent. When airliners lose their IFF ATC has a hard time picking them out depending on their altitude and distance from the radar. 2) Human nature, controllers are trained to focus on and look for aircraft not birds, sure they know what birds can look like and if they are not busy and bored they can tune the scope to pick out targets like that. However, it is not standard practice and not something they do on a regular bases. Now all of that said, if you think you are living in the shadows and they will never notice little ole me. Well you are likely to be wrong, and more so than you may realize. Unless there is a problem with a facility’s recording capabilities, all raw radar return data is recorded and kept for quite some time. Given the right software, and they have it, along with the right experts and time, as well as radar data from other nearby radars, and they can make an accurate determination of where your drone was and at what height and time. Yes, big brother is watching even the skies. Bottom line, you are taking a risk if you are not following procedure. If something happens they may have the ability to find you and or determine what happened with or without your statement, it depends. Not to show how anything can be done, but a recent news story today, where a Blackhawk was “hit” by a drone in NY is a good example. According to the story the helo was just above 400’ over water or a shoreline, I can tell you from experience that may not be accurate. First, aircraft do deviate on their altitude by as much as 20 to 50 feet depending on pilot skill and attention. Next, a simple altimeter setting being off on the Blackhawk could have it flying lower than 400’, however, some more advanced variants (i.e. spec ops) do have radar altimeters and if set for 400 then the crew would get a warning. My point is this, at that low of an altitude and unless the radar site is close by with LOS, it is not likely they got a picture of the aircraft, helo or drone. Now the higher either goes the more likely they will be painted, if, if, if. In other words staying low and away from radar is your best bet and safest one. In this example, it may have been pilot error but whose, if the Army crew was too low, then it may be there’s. I doubt they’ll ever know unless they find some witnesses or the drone operator comes forward. …and yes, drones are to give way to manned aircraft, however, if an HH60 is swooping through at 100kts or more and really low you may not be able to move out of the way fast enough.
EDIT: It is fair to note that the drone altitude may say 400 feet but in reality it could actually be at 450 feet or so. This can be due to inherent errors in the system or pressure changes or a combination. Which means, in the Blackhawk example, the helo was right and the drone was at fault.
