MAX DISTANCE FLOWN
allyssongemelli
Flight distance : 2562467 ft
Brazil
I didn't find a topic with this issue. What is your max distance that you have flown?
Mine today I got a 1400 m, and shows Weak Signal. For safety I return a little.
And yours?
2017-9-23
Drshiwas
Flight distance : 892339 ft
Where was definitely topic regarding this maybe somewhere lost in the pages
My max distance from remote controller aprox 5,4km.
2017-9-23
allyssongemelli
Brazil
But, our dorne is a Pro in 5.8 Ghz? Today in city flying 70 m high, with 700 m it got weak signal, and I had to return.
2017-9-23
Hellsgate
Flight distance : 1991555 ft
Are you refering to distance from remote or max flight distance.
My max flight distance so far 9588 mtrs.
Max distance from remote 4268 mtrs
2017-9-23
allyssongemelli
Brazil
I didn't understan why the difference? Its a remote right?
2017-9-23
Hellsgate
There are two specific distances.
1.. distance from remote.
2.. distance flown in total
2017-9-23
Hellsgate
Dont confuse flight distance of combined flights  im only refering to a single flight
2017-9-23
allyssongemelli
Brazil
Ok, from a remote in a only flight! hehe Max far distance with remote
2017-9-23
Drshiwas
allyssongemelli Posted at 2017-9-23 14:18
if you are asking if mine are PRO, so no, mine are P4 standard. And achieving long distance you need to be very precise with pointing your controller directly to the drone.
2017-9-23
Lucas775
Flight distance : 50642090 ft
Furthest Distance flown from remote was 2 miles for me then again I only owned the P4 for a few days.
2017-9-23
imagine it
I live where there is little interference in certain areas and I've flown around 3.5 miles at times. Normally using 5,8 ghz
2017-9-23
imagine it
That's straight line from the controller out. Might could go further but that is about max to have enough battery to get back safely.
2017-9-23
Zeldon50
Flight distance : 11634 ft
I believe the FAA is monitoring this thread closely!
2017-9-23
Pardal-Voador
Flight distance : 989281 ft
Brazil
Fala Allysson,
O seu é o Advanced?
2017-9-24
allyssongemelli
Brazil
TUdo bem Pardal, o meu é Advanced. Mas eu ainda não direcionei bem o controle no drone, talvez seja por isso que deu um pouco de distância. Qual é o teu?
2017-9-24
Pardal-Voador
Brazil
O meu também é o advanced. Quando eu tinha o P4 standart, voava tranquilamente 5km sem nenhum problema.. Agora não consigo passar de 2km, e o que mais me incomoda é que a DJI pouco importa com isso, ainda promete que vai a 7km...
2017-9-24
allyssongemelli
Brazil
Então é um problema isso com o Advanced? vou testar outro dia pra ele ir em linha reta e talvez uma altitude mais baixa, pra ver até onde ele vai. Porque da ultima vez eu estava dentro do carro, e não tava apontando diretamente pra ele. Foi até 1.400 m
2017-9-25
Pardal-Voador
Brazil
allyssongemelli Posted at 2017-9-25 04:58
Eu já testei em vários lugares, inclusive onde não tinha interferência... Depois que a DJI mexeu no  lightbridge, parece que piorou muito em relação ao P4. A única solução que vejo é desfazer desse drone.
2017-9-25
allyssongemelli
Brazil
Esse lightbridge seria o quê?
2017-9-25
Steve Slechta
Flight distance : 31276 ft
Here's one of the recent posts from about a month ago:
Whats The maxium Distance/Altitude P4 Pro Can Fly?
Steve
Flight distance : 5852
Flight distance + Litchi: 72741
2017-9-25
Pardal-Voador
Brazil
allyssongemelli Posted at 2017-9-25 06:46
É a tecnologia usada para fazer a transmissão de vídeo.. O P4 ADV tem uma melhoria nela em relação ao P4.
2017-9-25
VetteGuyZ06
Flight distance : 429114 ft
so just curious...how far should a P4A fly in an setting where there are power lines, homes, trees.  Not in the city, but not in a desert either.  I guess you could say country, but with quite a few houses, normal power lines, and lots of trees.  Distance from RC, not total distance flown.  I have been 3200 ft, flew over a large parcel of trees, probably 2000ft, height was about 200' agl.  Was afraid to go any farther.
2017-9-26
allyssongemelli
Brazil
In my count was 4666 ft (1.400 m) but in a country with few tree, and power line. But I were inside the car, and not apointing direct to drone.
2017-9-28
rwcreigh
Flight distance : 111818 ft
My max flight distance so far 3487 mtrs.
2017-9-28
Chatikib
Flight distance : 821821 ft
It is like a comparison of apples and oranges. Tell what type of drone you are using, or you have flown in open field and what kind of modifications you have been made.
2017-9-28
allyssongemelli
Brazil
Ok, my is a Phantom 4 Advanced. I wanna know if the range is not so great as the Pro?
2017-9-28
VetteGuyZ06
Phantom 4 Advanced...i have only flown 3200 ft. away from remote control.  No modifications.  Drone is 2 months old.  I'm still trying to learn.  Just don't want to try and go a mile and lose it in the top of a tree somewhere.
2017-9-28
Sportbike_Pilot
Flight distance : 10278435 ft
Flown the MP, almost hitting 34,000 feet distance (round trip on single charged batt).
2017-9-28
Chatikib
VetteGuyZ06 Posted at 2017-9-28 10:24
Smart guy! +++
2017-9-29
