TdotTrucker
Flight distance : 119272 ft
DJI Thor Posted at 2017-10-16 01:00
I am sorry for the late reply. As we had mentioned above, the data did not show the error of the drone, if more trusted data could be provided, please send it back to our support, and I had also forwarded your needs to the colleague who is following your ticket. Will try to see if there is anything we can do.
Hello DJI Thor,
Unfortunately, I do not have any technical data such as a separate flight log. In reviewing the flight log more closely I can however see an issue. Just before the point in which the drone makes contact I can clearly see that the throne log turns to face away from the object that it hits and then according to speed references you can easily tell the drone drifts backwards.
Just to clarify your data, first I did not ask the drone to point in the direction it was facing before is began to drift backwards, you will need to carefully check the data to verify this, as the drone is drifting backwards towards the object, your data is not showing that I applied full left stick and full ascend or up stick. Please as well verify this information on the data.
Witness to the incident was my wife and my sister-in-law who both observe the drone behave unexpectedly and erratically . They observed the drone drift backwards. I stated to them that it is not responding, I cannot control it or stop it.
Thor, I understand what your technicians are trying to say based on what they have in front of them. But there is a lot more to a big picture that I just bytes of data recovered from the loss. There is usually weather information, technical information, witness accounts, pilot accounts, and much more than I can help you see the bigger picture I ask you a question you please try and answer without dodging it please, if there are certain stick commands that are missing from the data, and if you review the paragraph above this one where I indicate two witnesses that saw this occur including what I said to them, how can it still be pilot error? How can you explain missing data, two witnesses, and stated to those two witnesses that I cannot control or stop it!
The only explanation I have for missing data from the flight log is because the drone did not receive that data or stick commands, Would this not be a correct assumption? |
