DJI Susan
EYE SKY Posted at 2017-10-19 21:06
Hi there, As I have said when i connected my ipad to the RC after not having flown for awhile, I updated the app in is now version 3.1.15 it then said update RC (not sure what version I was using but it was at least 2 years old), so I did using the network connection through my iPad. I did not use the micro SD card . it was after going to the web site to update the aircraft and batteries that i read "do not update older versions of RC controller firmware if the "PHANTOM 3 remote controller firmware is below v1.3.20 I should only update using the micro sd card. Unfortunately this is exactly what I have done. The version showing now for the RC is 1.9.2 . Since doing that I have had many problems.
Q: can I delete the RC memory version 1.9.2 and then update using micro SD card?
If the controller firmware is lower than 1.3.20, you need a SD card to update to 1.3.20, then update to the latest firmware via DJI GO. According to your description, it seems that the update is successful, there is no need to update via SD card any more.
Click About in DJI GO to see whether the controller and aircraft firmware matched, then link RC. |
