Genghis9
Labroides is correct, do not calibrate your compass unless the system says so. Even than ensure when it does that you are not near some interference such as a metal table, sitting on reinforced concrete (i.e. rebar), or power lines of some kind; if you are pick up and move away first and see if that clears the problem. If not then recalibrate per system direction. |
