Spark hovering up and down not stabilizing
12
17905 57 2017-9-24
ArnoSpark
Kenya
rgffranco Posted at 1-27 16:22
Hello there. It's my first post, hope to help.
I've had this problem and could solve it today.So far, after a few tests, no more problems, working fine, as before.
Hi it happen to me once but i did what  40# mentioned by  Downgraded the Firmware as well as rolled back to 4.1.15 and since then never happen again.
2019-1-27
ArnoSpark
Kenya
The you tube link not working on my side kindly check it
2019-1-27
rgffranco
Flight distance : 233 ft
Brazil
Hello there.
I'm sorry to say that the problem came back and so the solution above DID NOT WORK.
I'm sorry.
Just left the drone with a specialist to see what the problem is.
For the Brazilian people out there, the website of the technician is:
www.doutordrone.com  (Brasília-DF)
2019-1-29
RJB1
Flight distance : 32031 ft
Seems like there is at least 3 threads with this same problem. There is mine one too which I mistakenly put in the discussions section, there is another one somewhere where a Malaysian guy has a big video up of a number of people having the same problem. The fix for me in the end was to plug into the DJI Assistant program on my computer and to re set to factory settings. Then to take off using only the controller, not your phone. I'm wondering if the common link is taking off using the phone instead of the controller. Here is the video of mine doing the same thing.
2019-2-6
Wolferl
Flight distance : 23793 ft
Austria
RJB1 Posted at 2-6 04:14
spark hop
Hi,
At the end of the above video you see dust being stirred up by the Sparks propellers. Could it be that the optical system is getting confused about the actual height? I mean, in this forum you can find threads where even simple fog causes problems because the opti system thinks theres ground...
Can you try the same with a clean blanket or start mat or something?
Cheers,
Wolferl
2019-2-6
RJB1
Wolferl Posted at 2-6 11:03
Hi,
No its not that, that just happened to be one area where I tried it and had the camera on. Other launch sites were clean and free of objects. It's as I said, it seems to be related to taking off using the auto take off of the DJI app on the phone.
Here is the video from the Malaysian guy I was talking about before.
2019-2-6
fans6f4c4b0e
Flight distance : 157766 ft
South Africa
A regular problem on 2different sparks since I updated my firmware 2months ago. Since then spark still randomly does the hover dance, and other times take of is perfect, I've also done the spark dance, down grade and upgrade firmware, new props, different landing positions, using remote&phone,phone only and gesture controll, yet still the take off dance continues randomly, perhaps this is concern we need to keep an eye on before spark meets floor and damage keeps us grounded. Could it be the device Iam using, could it me the battery could it be the firmware.
Not sure and scared to find out DJI repairs not cheap and just not worth the damage to fly.
2019-4-25
S.J
Flight distance : 322454 ft
India
fans61699a75 Posted at 2017-9-24 06:46
If i could chose again i would not have bought this spark also the mavic i think. There are simply tooo many issues with the spark
there are so many issues with Mavic 2 pro also..
All DJI products are having their software outsourced...
2019-4-25
Sayhelloforme
Flight distance : 8133219 ft
Tony Nguyen Posted at 1-15 01:23
Thanks for support. I upgraded my drone to Mavic Air and good for me now
Happy for your new purchase.
I just had the same exact problem you had  and it was my propellers .
I got some 3nd party propellers.
I changed them out back to DJI and now everything is back to normal.
2019-4-26
Mhinc
Flight distance : 151467 ft
Any change your sensors are dirty on the bottom?
2019-4-26
sparkens
thats what happened to me check it out on youtube: (https://youtu.be/okhqmMNpELQ) Its really weird
2019-11-21
sparkens
Wachtberger Posted at 2017-9-24 06:45
I would recommend to open a support ticket, export the blackbox and all flight data and send it to DJI. This is definitely not common behaviour of the Spark and can be solved one way or the other through DJI: http://www.dji.com/support
well it seems common according to all this my spark is even doing this
2019-11-21
MartyTravels
Flight distance : 394173 ft
Thailand
Bro, send it back and get a new one...but no spark. This is a new dimension to this problem. No way you'll fix that on your own for good.
2019-11-22
Jakab Gipsz
Hungary
I do it even though I haven't updated it 1 year ago. Do it with only one battery.
  I saw a video of it being caused by a connector, which seems logical because no one's new Spark will fail. After 2 years I had this problem.
A software bug is unlikely, because it happened even if the owner was upgraded or not (like me).
It is caused by the uneven (fluctuating) performance of the motors. No errors are detected in the software, there is no sign of any errors in the log files. Mine landed recently and I pushed the stick up. Propellers crashed, but the log file is completely error free.
Disassemble and disconnect contacts, apply contact spray.
Sad that DJI listens to this as well as other bugs ...
PS: google translator......
2019-11-25
S-e-ven
Flight distance : 5922034 ft
Thailand
sparkens Posted at 11-21 13:23
thats what happened to me check it out on youtube: () Its really weird
Send the link to the video with the spark to DJI
Try to get a mod or admin involved, who can organize that and bring the info and the warranty request together.
That is neither new, nor unknown for DJI.
It us just not to reproduce, under all starting circumstances in the dji repair centers.They dont have that much time for either bird.
Use your warranty.
Or:
In case you still can give it back:
Give it back, buy another one!
2019-11-25
John R. Jaromahum
Philippines
Use original DJI propeller.
2019-11-26
fans707d79ca
Flight distance : 42461 ft
Mauritius
I would like to share my repair for this problem. My drone would fly properly with prop guards, but without it, it would bump several times and refuse to take off.
I flushed the motors using Electra Clean Spray, and I cleaned the 4 ESC boards which probably had traces of moisture.
And now I can fly is with and without prop guards.
2020-8-11
Jakab Gipsz
Hungary
fans707d79ca Posted at 8-11 05:25
If you opened and disassembled it, moving the connectors may have solved the problem, as I did:
https://forum.dji.com/forum.php? ... D635%26typeid%3D635
2020-8-11
12
