HereForTheBeer
Flight distance : 5381368 ft
MPV Posted at 2017-9-25 00:49
Q: So the drone showed disconnected when the gimbal moved up and down, then it recovered itself, right? Could you please help to check if the video recorded the gimbal behaviour in the SD card, or it is just the transmission video.
Hi Thor and thank you for your help.
this is what i suspect as well, you encountered a gimbal reset and it was not trees or anything. mine does this at 3.88GB, but otherwise all the same. it can have 100% perfect signal, the video almost always stops before the reset occurs so hard to prove it without screen capturing it. for reasons i dont understand the aircraft disconnects with gimbal resetting. sometimes connecting then disconnecting and then reconnecting again several times even with solid signal..
if it was trees the signal would fade, not suddenly drop out.. |
